Safety of 110v transformers
The reason that 110v "site transformers" are safe(r) is because they are isolating transformers, not because of their 55v centre tap or 110v output.
As stated earlier in the thread, it's not the voltage but the current that will kill you - as little as 75ma (source).
However, any electrical force is dangerous only when it uses you to complete a circuit. With UK electrical mains, the physical ground is the return path for the electrical current so if you stick your finger on the live pin while standing in your garage then the electricity flows through your hand, up your arm, down your chest (unfortunately, traversing your heart) down your legs, into the ground and back to the substation - you have become a piece of electrical cable*.
Site transformers are isolating transformers, which means that they present a live and neutral (return) on the other side of the transformer which are not connected to the physical earth. So if you touch the live conductor the electricity has no path across your body to the return (unless you are dumb enough to also be touching the neutral with your other hand!).
This is why many sites demand 110v kit - there is a far higher risk of equipment or cable damage on a busy site and the isolation massively reduces the risk of someone receiving an electric shock.
(*This is why RCDs are essential - they detect an uneven leak to earth, probably caused by you sticking your finger in a 240v socket, and disconnect the supply rapidly. Most RCDs are designed to trigger at 35ma or less)
Touch voltage (the level at which it will penetrate your skin) is 50V on dry skin (less if your soaking wet...prob closer to 25V) because of that...a 55V shock is far less likely to do you serious harm than a 240v shock (I've had a 240 belt more than once...last one off a badly put together fusebox...that hurt badly) Seemingly USA 120V is more likely to kill you though as they run 60Hz which is more likely to cause your heart to fibrillate (or so I was told)
some will allow but most wont and if they dont want u to use them on there site its there choiceOn that basis, why don't sites allow 240v gear on the condition that 30 ma rcd's are used?
i wouldnt bank on that. ive had hold of a few live cables and stood on damp ground fortunately there was rcd fitted but u still get a hell of a shock before it trips and it hurts and u wouldnt want anotherI can think of many instances over the years where I could have been seriously hurt by electricity if I were using a 240v power tool on site. You can still get a tasty belt off 110v (even at 55v potential to earth) if you're working anywhere near sea water for instance as it conducts very well. Put a 240v tool near it and you're talking life-taking jolts or you could use a RCD in which case you won't worry about getting a jolt, or even doing any work because it'll trip at the first sniff of getting damp.
