Screwdriver
Used a small pc power supply to do lathe dial. Its a small item so used a spray can cap as the container. Had an outer bearing race perfect size, used that as anode, with dial sitting ontop/inside. Markings are stamped rather than etched, so no damage. Used some old rag as a spacer... Pb batterys use fiberglass between the plates, anything thin and porus will do. Added quite a bit of salt. On 12v it wanted 20 amps. 5v was quite a bit less, but still only needed half hour.
I wouldn't recommend salt as an electrolyte, you will be generating chlorine gas. You'll know all about it because it will stink. Breathe enough of it and you will die. Ideally you are aiming at less than an amp especially for delicate stuff.
Electrolysis begins at about 1.2v and you shouldn't really ever need more than 6v unless you're in a real hurry. Incidentally, never use AC. Lots of weird chemical stuff can happen during the process, poisonous and/or explosive gas being the least of your worries.
S.
