Only leak I had was my own fault. I didn't tighten the new nozzle properly and the filament oozed through the threads, insulating the nozzle from the hot-end and causing a blockage. Had to remove the hot end, pull the heat break tube and nozzle out, run a M6 tap through the hot end and wire wheel the nozzle and heat break to clean the threads for good thermal contact then re-install them (properly tightened this time). It all worked great afterwards but I won't do that again...
I think it's done it to me twice, now. First was with the original nozzle in, & later down the line with a replacement I'd fitted. How tight is tight enough, for the nozzles?
