Kent
- Bowland, Lanacshire,UK
well i have a 3hp 150l sip compressor single phase that i was using in my unit perfectly fine, had to give up my unit so the compressor is in my shed, the shed is at the bottom of the garden with no electical supply to it, i've tried the compressor using an extension lead, the compressor tries to start but then it trips the power inside the house
i can't really afford to have proper mains power put into my shed at the minute so need a temporary solution, anyone have any links to decent extension leads or other items so that it doesn't trip the power out in the house
Its the start up load that is higher than the running, sometimes its substantially higher. You need a good spark on site to sort this one I suspect otherwise you chasing you could end up chasing your tail. Were are things connected what is the load already on things back at the house, I am no spark but you wont fix this without someone looking at the existing wiring and fusing I suspect. You might need to hire or buy a smaller or engine driven, do some alterations to the wiring at the house who knows.
