That’s great. Thank you. Exactly what I was looking for. Appreciate all the help so farLocal library or tech college may have a copy of "Woods Practical Guide to Fan Engineering". Quite an old book, but still good on the basics. It looks as though you may be able to download it from here:
https://vdocuments.mx/flakt-woods-p...dfauthors-preface-this-the-third-edition.html
Filter manufacturers will tell you the pressure required for a given air flow rate. Damp dust can quickly clog a filter. Modern filters will usually have a self-cleaning facility, very old systems may have nothing more than some hanging filter socks that have to be emptied manually (not a particularly pleasant task).
The fan in your photo has a large number of forward-curved blades, on which dust can build up. One with backward-inclined blades would be better for handling dust, and also able to generate much higher pressures (see comment from Parm, post #14). Paddle blade fans are even better at handling a lot of dust, but less efficient (take a lot of power for any given air flow rate).
General design procedure is:
A: Particle size and weight will govern the air speed necessary to capture and transport the dust.
B: Calculate the volume flow required. If possible, use a close-fitting hood around the source of dust, so that you can achieve the required capture speed without shifting vast volumes of air.
C: Select a filter, based on the particle size and the air flow volume. Manufacturer’s data will tell you the pressure drop through the filter for that air flow.
D: Add on the calculated pressure drop through the ductwork.
E: Knowing the the air flow and total pressure, you can select a fan.
