DAPPH
as dyslexik as I'm daft
Just re read the above post......... The side weather strips are fitted on the inside of the door frame so th closing door pushes up against them .
On most U & O doors there is an integrated metal lip in the top half of the sides of the door, it should shoulder up the the frame when the door is closed .
Getting the frame to fit the door is not easy unless you set up one of the verticals first and nip it tight , then calculate everything from that . i had a dozen or so 4 x 1/2 thick wedges that I used as packing's , drilled through them and left them in place once I'd cut the excess off after the job was done .
I also sealed all of the frame inside and out with Silkaflex mastic once the door was hung right and everything tightened up , for i found water was getting blown in behind the wooden frame thus soaking into the block work if we got a South Westerly giving it what for .
