I did wonder if you were making a camouflaged nesting box for a pigeon loft!
imo theres still too much wire... do you feel the torch pushing back at all as you weld?? like the wire is hitting the metal and pushing against you rather than melting???
as for the mocking, please don`t take offence i personally dont mean anything by it.. just a bit of banter...
next time you have 2 pieces joined corner to corner maybe try a few manly tacks along its length with a 10mm gap between them and get some pics of that?? a stationary burst of 1 or 2 seconds should be ample and give a nice spot without too much weld build up on the topside and penatration on the inside and of course without blowing a ruddy gurt hole in it...
I reckon for thin stuff that distance torch to work is almost too much. The contact tip is recessed so I'd go a lot closer, occasionally touching the shroud to the work.
Yeah I started off with it dead close, but then you can't see what you're doing![]()
