I'm filling in the sporwelds that got drilled straight through , then I want to put new panel on welding to that part@G1zm0 the machine you have should be fine for filling holes in relatively thin sheet metal in the right hands. As @eddie49 says it isn't clear what exactly it is you are doing, you mention spot welding but it does appear to be more filling holes? At a guess I'd suggest your stick out is too long and you might be struggling to see the puddle if you are using the fixed shade handheld mask that came with the machine. A bit more info about what you are trying to achieve and what you have tried already would be good..
