Tupers
Now that the engine's back in with the charger and throttle body mounted I've turned my attention to the engine steadies.
I started with a pair of old suspension tie rods, cut them down and gave them a clean of the bench grinder.
Both steadies use a 5/16 UNF turnbuckle and a rose joint on the engine side. The old tie bar will be threaded and bolt through the body with a rubber bush on each side.
The R/H steading will be bolted to the standard position on the block and the body side will bolt through the engine bay crossmember.
The L/H steady is mounted to a bracket on the water pump that I made a while ago and will go through the crossmember the same way as the R/H steady.
