You are over thinking it, many trucks/boats/rvs use standpipes on their main fuel tanks, we had one on our old petrol boat, never blew up in the 6 years we owned it, it was 25 odd yrs old back then.Petrol, it's not been drained yet, but I think we can safely assume it will stink of fuel for a long time after it is.
Drilling metal is still a form of hot work... Lower risk, but considering it's a petrol tank, still represents a risk of ignition.
Also, not really confident that a singular bulkhead fitting is going to form a seal that's vapour tight against petrol on hot days, or even fully water-tight against spray in the winter.
The LR fuel senders use a 6-bolt pattern flange with cork-rubber gasket, which seals using machine screws tightened into captive nuts.
It's mostly that I think the underside of underside of a Landrover is going to be pelted with spray and periodically immersed, which is probably more than a standard bulkhead fitting is designed to deal with, so I'd rather use a proper threaded or gasketed flange connection where I can get a decent seal.You are over thinking it, many trucks/boats/rvs use standpipes on their main fuel tanks, we had one on our old petrol boat, never blew up in the 6 years we owned it, it was 25 odd yrs old back then.
I think it depends who you ask and where it is, because the term isn't precisely defined...Not sure drilling tin is classed as hot works? and if it is lightly spray the drill bit with water whilst drilling the hole.
Standpipe fuel supplies go in from the top of the tank not underneath which is far better than welding a threaded port into the side or bottom of the tank which is prone to cracking.It's mostly that I think the underside of underside of a Landrover is going to be pelted with spray and periodically immersed, which is probably more than a standard bulkhead fitting is designed to deal with, so I'd rather use a proper threaded or gasketed flange connection where I can get a decent seal.
Youve been fine, as have I, but many have got it wrong, needing a new tank and underwear or worse. Nothing wrong with fully considering the hazards and potential substitutions / mitigations to reduce them. Its a mind set learnt in a working environment, but-the concept of thinking things through is very beneficial, comes as part of the PPPPPP.Jesus there are a lot of people over thinking this. I repair motorcycle fuel tanks.
Just fill with hot soapy water a few times and rinse out. Then steam out with a wallpaper stripper. If you want to be extra safe tue purge with exhaust fumes.
Then it will be fine.
I do this and haven't blown myself up yet.
I think you've got the sequence wrong.
Caustic or steam clean, then fill with gas or water.
If you have concerns about internal corrosion being porous and holding fuel then after the first caustic wash use citric acid, preferably with it's ph buffered back to 6-7 range and a surficant.
Which way is the opening pointing, during the leaving out in the sun bit? Downwards would seem best, because fuel vapour is heavier than air.Whenever I weld the aluminium tank on my bike I empty out the fuel, leave it in the sun for a while then weld it.
This is it exactly it, and the mindset just slowly takes root in your thought processes, as a young man I was a little cavalier and willing to take significant personal risk to get the job done.Youve been fine, as have I, but many have got it wrong, needing a new tank and underwear or worse. Nothing wrong with fully considering the hazards and potential substitutions / mitigations to reduce them. Its a mind set learnt in a working environment, but-the concept of thinking things through is very beneficial, comes as part of the PPPPPP.
Fair, it's the very far end of the spectrum of control measures, and wouldn't be a solution anyone would reach for unless they already knew about them and used them...However I think dreager tubes etc are a bit OTT for a landrover tank…..if really worried after cleaning and water filling, flame on a long stick, see if it ignites. With the reduced ullage risk is minimal.
Ooooh, controlling RAMS, PTW, & MoC can be a thankless task, but probably one of the most meaningful in terms of keeping people safe.I was once the man who said yea or nay on a COMAH site by my signature!
Steaming out was a method I have heard of but never used.Is anyone willing to share either:
- a detailed procedure for purging automotive fuel tanks prior to welding,
or
- details of a firm who could carry out a clean and provide it back to me with paperwork proving it has been tested free of flammable atmospheres.
If it was something bigger I could probably borrow a gas detector from work, but we don't have anything with a long thin probe to get in there.
In case you're wondering why I want to do such a thing...
It's a sub-project of the Landy build, I want to add a threaded boss to the top of the tank, for a dip-pipe to act as a self-limiting secondary fuel draw-off to allow me to fit a (period appropriate) eberspacher "benzin" heater.
Given the high risk nature of the job, I figure that planning months in advance is probably the best approach here.
Depending how difficult/costly this is to do safely, both a secondary tank, or just tapping into the main fuel feed are alternatives with their own downsides, but reduced risk of explosions...
