When I sprayed my precious, I used a 3M branded face mask (7502), with 6059 ABEK1 filters, topped with FFP3 dust filters. That was the best solution I could buy. I was happy with the filters, because I could not smell the paint. I think that's something.On the air fed system for spraying, I am hoping for a bit of guidance from you experts that are more up to speed on what should be my requirements for an adequate system for part time spraying on my own classic cars, so i am not looking for a commercial set up solution. But the proper requirements for a healthy outcome is my main criteria.
I know a lot of my friends just spray with an ordinary charcoal filter mask, which I tell them is totally inadequate for spraying isocyanate spray paints. And they just laugh and say " sure look at me, I'm fine"
And my reply is "when the damage is done, there is no going back"
So I only have one set of lungs that I want to look after.
OK I must check that out, but I thought the recommended procedure for isocyanate 2 pack was air fed. Did you use isocyanate on your car. Was that the only option to you at the time then. Thanks, TimWhen I sprayed my precious, I used a 3M branded face mask (7502), with 6059 ABEK1 filters, topped with FFP3 dust filters. That was the best solution I could buy. I was happy with the filters, because I could not smell the paint. I think that's something.![]()
Im not sure, I used Valspar 2K poliurethane paint. That paint was my only reasonable option, what was available.OK I must check that out, but I thought the recommended procedure for isocyanate 2 pack was air fed. Did you use isocyanate on your car. Was that the only option to you at the time then. Thanks, Tim
With a small amount of welding, I'm assuming that most people would suggest grinding back and/or keeping your head away from the fumes and stay in a well ventilated area. I use 3M 6300L half masks with a P3 filter for dusty grinding / sanding tasks and was wondering whether I could find a suitable filter to further reduce the risks when grinding/welding BZP and galvanised steel. 3M have a filter selection website but it requires some specialist knowledge (that I don't have) to use it with confidence. 3M P3R 2138 and 3M P3 6038 may be worth looking at but do not take this as advice.Hi, Its my first post, so hopefully its in the right forum.
I am doing a small repair on my classic car, and am using 1.2 mm galvanised metal sheet. I would like to know the best 1/2 face mask to use to protect myself from the fumes from the welding of galvanise metal.
I have seen some reference to 3m masks, but not actually an identified type that I can buy.
Any help would be greatly appreciated. I know I could go for an airfed system, but as its a only a small amount of welding, about500 mm in total, I would prefer a less expensive option if there is one.
Thanks for your help.
Tim
