Hattori-hanzo
- Uk
With the blade finished I could start working on the wedge.
I had a piece of padauk that had a small amount of contrasting sapwood which I thought would look nice in the wedge.
I cut the wedge out and started shaping it with a coping saw and files.
With the wedge partially formed I added a small cupids bow detail to the end.
After test fitting the wedge to make sure it was seating uniformly with the blade I cut a small piece of matching padauk for the front infill of the plane body.
I then glued the front infill and bed into the body using strong epoxy.
I cut some small wedges to hold them in position while the glue cured.
Once the epoxy had cured I used my makeshift sander to blend the padauk infill to the body.
And finished the curved end to the wedge.
I was now ready to start flattening the sole of the plane. I masked up the padauk to prevent it getting dirty while lapping the sole.
I started on a piece of sheet glass with 180 grit wet and dry paper, then moved up through the grits to a 400 grit diamond stone.
I went up to 1000 grit diamond stone, the sole was starting to get a nice flat sheen.
Lastly I gave the sole a quick polish with a strop and some metal polish compound.
