mindmejacobs
New Member
Set the bottle guages first with the torch valves open then close each torch valve in turn and watch the bottle guages you could see the pressure change so readjust them up to about 5psi.light the acetylene and turn it up till you just get the soot dissappear then add the oxy till the blue cone is slightly rounded. Practice practice practice then when you think you've cracked it a bit more practice a number 2 or 3 nozzle is fine for panel work good luck
