ajlelectronics
- Gloucester, England
It’s expensive rubbish.
And unsuitable for that application. Epoxy primer is the correct choice.
So epoxy stops rust completely? Can I paint it onto rust?
Noted, thanks.
A few questions about por 15 if anyone is able to answer them :
Is it sandable?
Can I paint over it?
Can I body filler over it?
Having now seen the van I think its probably better to Artex it
Bob
Best way to bodge the arches - grind the rust out from the outside, quick brush of some zinc primer onto there (toolstation), throw some chopped strand in there.Haha. The van is in a family friends garden, I don't want to overstay my welcome so I'm trying to knock it out as quick as possible, welding on new arches is time consuming. The van needs a lot of work in other areas, to the point that I'd be better off buying another one. I'm happy to take shortcuts if they last a couple of years. I know it's a pos, but I want to be able to use it for business use and not look like a complete pikey. So with regards to the arches, I want to know how I can best bodge them? I can always do the job properly at some point in the future if need be.
The paint was covered in a lot of crap. I think it's been sitting around for a long time. The 40 grit was quite a worn pad but has removed a lot of it, I don't think it's left anything rough. I'll go over it again with a few different grades just to be sure.
Na, I wouldn't bother with 400 - just give it a wash and a quick rub with a green pan scourer...sand the arches to clean metal with a grinder , fill in holes with fibre glass filler , grind that to shape then body filler to smooth it
needs to be finished all over in 400...by which time you will be down to the primer and find your celly wont cover ...the snth was a better idea for a banger
i said red scotch pad and soapy water earlier but he's gone ahead and 40 gritted the whole van nowNa, I wouldn't bother with 400 - just give it a wash and a quick rub with a green pan scourer...
In fact, I'd white stonechip the bottom half of the van anyway
By the look of the van a tin of dulux and roller and brush for the awkward bits would make it look better
your not going to get a good result trying to spray it outside in this weather and going over it with 40grit was a
NO NO
