backpurge
Backpurge,
I thought that the general consensous was to weld from the corner outward to the edge of the angle ? And that if done into the corner , it would cause slag inclusions.. Or am I not understanding somthing ?
Oilcooled: why would 4mm not be suitable ? please explain further....
If you try to arc up in the corner due to the extra material you can end up with a cold start and the inherent problems associated with this.
Bit hard to explain in words but most corner joints are made up of 3 welds in a sort of "Y" shape if that makes sense, you would normally run one weld into the corner then deposit the next weld starting at an outside edge, run it into the corner ensuring you fully fuse all material then run out of the corner towards the remaining outside edge, if you understand this you are a better man than I.
Will try and take some photos to explain better if needs be
CEP+, 140amps,E6013 4mm esab Miltrode electrodes and hot-start on 3 secs. (arc-force turned right down to settin 5 out of 0-99. The pics attached are: No1 -fillet on scrap steel in workshop. (Very happy with this). But second and third pics have flaws in the weld as you can see. The steel being welded is 80x8010mm angle iron. The trouble is that I cannot see what Iam doing wrong in the 2&3 pics as apposed to the first (practice weld). Iam trying to keep the electrode at the correct angle, but still no joy !! And to top it all, I cannot get the grinder in there to reweld.
please can the experts help me out ?
