rich r
If you're using 1.6mm, 2.0mm or 2.5mm rods (which would be suitable for metal between about 2.0mm and 5mm) then you can use a normal 13A supply for pretty much everything. Ideally you don't want to be at the end of 100m of extension leads, but for lower currents it's not too bad. For 3.2mm rods you're right on the limit and so a 16A supply is really what you need.
Inverter welders can do all kinds of clever things with the current to help start the arc and prevent the rod sticking as they actively monitor the current and voltage as it changes depending on what the arc is doing. So for example when a rod is about to stick it'll detect the sudden drop in voltage and reduce the current, and hence the heat in the arc until the rod has been moved a bit then it'll increase it again. Whereas a simple buzzbox is just a constant current supply really.
If your boat trailer plans involve welding something like 3mm steel outside then MMA with 2.5mm 6013 rods would be spot on.
