Nice looking weld bead that...what rods are you using?![]()
Yea thanks, thats something I’ve picked up since joining this forum, to quote someone? positive=penetrationMost 6013's will run nicely on arc positive or neg, the difference will be the amount of penetration you get.
Thanks Jim, the whole idea behind this box was portability after losing power to some of the sheds so an extension will be needed, wrestling an oil cooled welder through puddles is no longer fun! Hence back to the headlineNice welds!
as said earlier in the thread, it may not be putting out what is states, but hey, it works nice!
if you feel like being really safe, you could stick a nice big commando plug on that thing.
as far as an extension goes, if you can get away without one then do, and if you have to use one then use the shortest one with the thickest wires as possible. (within reason!)
Is it safe?
Well it's Chinese and made to the lowest price possible.
Is it likely to fail at some point? Probably. Will it kill you when it does? Unlikely.
I had a 32a plug waiting to go on, didn't expect it to have a plug fitted and wanted to check it was safe to use.
There is a CE certificate in the book for what it's worth.
im not 100percent but think its a 50metre extension lead i could use on my thermal arc fabricator that works on 240volts or 110 v id have to look at the book for sure thouNice welds!
There's definitely a fuse fitted (with fwiw 13a written on it)it's the first thing I checked. The cable to the plug seems heavy duty to be fair. Those commando plugs look like a good idea think I'll get one, ta.
Is this welder safe?
Yes, thanks for all that though.I switched from a sealey air cooled transformer welder to an inverter for welding around the farmyard like you. First time I used it in the cubicle house for repairs I had to keep turning the power down in the inverter as I kept blowing holes, with the sealey I had to have it wound up to 180a just to get it to weld because I was running on 30+metres of 2.5mm2 extension lead.
What I'm basically saying is that an inverter is more efficient as it doesn't have a big transformer to heat up, so it doesn't need as much juice to feed it. So when running on long extension leads you can get away with a lighter cable than you would with the oil cooled.
All my welding leads are now 2.5mm2 arctic or rubber flex with the blue 16a commando connectors, a whole lot safer & stronger than 13a on a farmyard. It also puts most people off borrowing the welder!I only have 1 long 16a reel, most leads are in 10m lengths & just coiled up for storage. You do know to have an extension reel fully unwound for welding?
You have said that the cable from the welder to the plug seems heavy duty, so it probably is 1.5mm2 or even 2.5mm2, and probably has three cores.Hence back to the headline Is this welder safe?
Does say something about earthing the case in the book, must read all 2 pages properly and check all again.You have said that the cable from the welder to the plug seems heavy duty, so it probably is 1.5mm2 or even 2.5mm2, and probably has three cores.
However, some of these imported boxes only have a 2-core cable, and even when there are three, the earth wire is cut flush on the inside and not connected to anything.
The correct wiring should be a short flying earth lead inside with a spade tag onto an earth point riveted or spot-welded to the removable sheet metal case, or the welder's base plate. However, maybe the case of your Rohr welder is all plastic, so it is effectively double-insulated ?
These inverters usually have plastic front and rear panels, with a U-shaped wrap-around sheet metal case, which should have a connection to mains earth as mentioned above. Check for continuity between the earth pin on the 13A plug and the case, or it's fixing screws, or any mounting bolts on the base plate of the welder.
