Almost but not quite - that one needs the roller cage to be removed first and is really a clamp, whereas the splitter goes behind the outer and the face that it is up against and forces the wedge in creating a gap for a three leg puller's 'toes' to get in.
You literally need a bearing splitter or a knife in which case you need a very shallow angle to force the bearing off the back of the housing/shaft. In which case your part need to be machined as one piece in order to drive the bearing off the shaft evenly.Almost but not quite - that one needs the roller cage to be removed first and is really a clamp, whereas the splitter goes behind the outer and the face that it is up against and forces the wedge in creating a gap for a three leg puller's 'toes' to get in.
Not seen that video but I do follow Curtis !
The fun methodOut of interest, cant the bearing be cut off.
Reminds me of Land Rover axle oil seal wear collars.Out of interest, cant the bearing be cut off.
Ah right that does mean extraction rather than abortion.I’ve done one (of four) by mangling the cage and using a drift on the step that the rollers sit on. But really I only want to change the big rotary seal that is behind the bearings but to do that the bearing has to come off and remain in good enough condition to go back on.
See post 1.I'm watching a few on eBay. See if any can be had reasonably. What is the size of the bearing?
Not as daft as it sounds. Print in PLA, entomb in dry silica sand and 4% sodium silicate. Set with carbon dioxide. Burn out the PLA in my pottery kiln and cast as someone suggested in aluminum bronze using my induction furnace. Al bronze has amazing tensile strength exceeding that of steel! (Google tells me!)Print it!
I'll get me coat...
