Seadog
Save the planet. It's the only one with rum!
- NE London - UK
That's what I thought you were referring to. How does it function?its the one that has the wound copper pipe going in to it from the valves ,
when the pressure builds up at the bottom theres a type of piston inside and its spring loaded it can be adjusted for diffrent pressures . when it lifts it opens the port feeding the valves and holds them open till the pressure drops then closes leaving the valves free to compressThat's what I thought you were referring to. How does it function?
So to recap - you need to fill the tank full with water, then pressurise it to 1.5 times the working pressure.
The working pressure is the pressure your relief valve, fitted to the tank, will lift (so you need to get one of those).
You will need an air pressure switch with adjustable differential between start and stop.
You will need a solenoid valve that gets fed from the normally open contact in the presdure switch, so that it dumps the air in the line between the compressor and a non return before the tank (unless there is a mechanical one built into the compressor).
I'm sure someone will tell me I'm wrong, but those are the bits I'd expect to see.
Edit to add, I've used a fridge compressor to pressure test before now, so long as the tank is full of water the energy release factor will be low (should it fail).
But surely that means that the pumpcontinues to run. Where's the pressure switch?when the pressure builds up at the bottom theres a type of piston inside and its spring loaded it can be adjusted for diffrent pressures . when it lifts it opens the port feeding the valves and holds them open till the pressure drops then closes leaving the valves free to compress
yes the pump continues to run along with the motor but it stops the valves from closing and compressing when up to pressure and just cycles the air through the pump doing nothingBut surely that means that the pumpcontinues to run. Where's the pressure switch?
yep best ignoring it and fit the electrical pressure switch but there good if you are running the pump of a diesel or petrol engine i had one on my 90cfm v twin run off a twin lister diesel engine for shotblastingInefficient with the cost of electricity these days.
"he line between the compressor and a non return before the tank"You missed a non-return valve, but I'm pretty sure i can see one in the pictures. I can't see a mechanical unloader, neither can I see a pressure switch.
Drunk this early @mtt.tr ?Only part if change is do for a self unloading switch
You should try Welsh, I might understand that...
Edit to add - the only thing I think you're saying is to add an unloading switch? But that would need to mechanically lift valves etc? Wouldn't it?
general up to 14 or 18 cfmSome pressure switches have an unload valve built In. Only really on small compressors mind
Got one of them on my piddly compressor. It farts a bit on startup sometimes.This type![]()
AAAAA | eBay
Find many great new & used options and get the best deals for AAAAA at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
i use my cheapo switch to operate a separate contactor to operate motor .the ones in the pressure switch arent up to muchGot one of them on my piddly compressor. It farts a bit on startup sometimes.
