123hotchef
- Kent
what one is it? I need a second fixthat reminds me i need to sell my Paslode
1st fix then i have the newer one IM360IM350 90CT impulse, well used, but still fires nails in better than I do...... I have two, so will keep one, but the other can go...
heads are too big on these for the second fix I would be using them for!aye, in theory, but when needs must, you can second fix with any size of nails ........ especially if you're a rough old xxxxxxxxxx like what I am.... hahahahahah
ha ha i use mine for all kinds of fixing at home!
ha ha funny its a different cliental here lol they like hidden pins.that's just being fussy...... if it stays up, job done.... a, 1" #8 screw or a 4" nail same result...............
i have a nice one thats up for grabswhat one is it? I need a second fix
tell me more oweller weller ohi have a nice one thats up for grabs
come in to the house via PMtell me more oweller weller oh
As the female on the gun is rough, it minces ptfe tape, it means an annoying clean out evey lube.I have a dedicated air line for air tools with a lubricator and I keep separate hoses. But if you're not using it much a squirt of oil down the inlet will be fine
Nice idea thanks!
Shouldnt do as you’ve positive pressure in the line but best practice is to have a dedicated spray line.As the female on the gun is rough, it minces ptfe tape, it means an annoying clean out evey lube.
can I put the oil in the end of the 600mm whip hose?
and I assume that won’t get past the female QR coupling and eventually up the main 10 mm hose ? (defo do not want that, as its used for spraying paint too).
Yes a squirt in the whip hose will be fine. If you pull the trigger as soon as you reconnect the oil should go straight into the gun.As the female on the gun is rough, it minces ptfe tape, it means an annoying clean out evey lube.
