If you've got M18 already, then I'd go for the M18 Mid-torque gun.i dont have any batteries for m 12 stuff anyway, ill be buying battery for the impact do probably better going 18 than 12, no?
I think I would always spin on to a low torque and then check with a torque wrench, so I am not sure I see any need for the bluetooth and worry it is potentially something fragile in a tool thats not used in a fragile way...!That's the original one with the Bluetooth. I used the bluetooth when I got it so as not to over tighten wheel bolts but soon resorted to spinning the nuts on using the lowest output mode and torquing up with the wrench. The bluetooth is just an option to provide a 4th mode to the standard 3 presets.
If you getting one then you may as well go for the latest generation like you linked to especially if you don't need the bluetooth setting
I guess I meant that the Bluetooth was potentially a relatively fragile component.There is nothing fragile about either torque gun but if you're going to go for the big one then get the latest that was in your second link.
I still think you would get more use out of the M12 Stubby that others and myself recommended.
This will get use on tractors, diggers mainly and then bigger stuff on my land rovers - would that alter the recommendation? I suspect that once I have the battery system and have saved a bit more, a more compact one might follow.
@reb78's requirements are a bit different, he's got a very similar use case to me with general spannering but also dealing with more plant equipment such as backhoes and tractors. The M12 stubby is great but can be replaced with general spanners without too much effort, however, there are situations where the Hi Torque M18 is invaluable in busting big nuts loose etc.Never heard anyone mention that the bluetooth had failed but if you don't need it then it's a mute point.
I'd gotten confused with the OP's requirements for a torque gun. If you are generally turning spanners the M12 range will have more tools for you.
For trucks or heavy plant maybe...if your looking to remove the wheel nuts and rusted large nuts you will need the 1000nm ones
Compactness makes a huge difference to usability...As what @Guzrik said I use my little half inch stubby more than I use the big 1800Nm impact. It's surprising what it does and it's so small, light and convenient.
