A 3-phase contactor has three contacts to switch all 3 lines. Single-phase has two.
I'm not familiar with starters for 3-phase and I have never needed one. Some starters may include a contactor.
A fo pulley sizes, take the size and RPM of the existing motor. Change the pulley by the inverse ratio of the motor speeds. If the new motor is half the old one then use a pulley twice as big.
Don't forget, with a 3 phase motor it can run in either direction, so when it's installed make sure it runs in the correction direction for the pump, if it doesn't swap 2 motor wires (phases) around.
Got it running today,seems ok,I'll give it a good test this week.
I see there's another thread just started with the same pump wanting to use a single phase 3hp motor,well I used a 4" pulley (the diameter is actually measured overall not to the 'v') and we know how that turned out lol
I'm using an 8" pulley now and the pump seems to be turning at a higher rpm than before.I'm thinking the 3hp motor I was using wasn't actually powerful enough to drive the pump at the correct speed.
It's something for the other poster to consider before he uses a 3hp single phase motor to drive that big pump
Oh and thanks to everyone who offered advice on this thread
Glad to hear you have got it going and you are happy with it, so 4hp motor and 8" pulley you used then, means you have more cfm and should last you quite a while if you don't neglect it too much, ugly queens need some love too you know
