According to the link 'wrong stuff'
As per my other post, is it? Ive still got a copper radiator. Is the red compatible?
My understanding was that red will cause issues with other components in old systems, so same understanding as you.As per my other post, is it? Ive still got a copper radiator. Is the red compatible?
The colour is not universal to all suppliers apparently. From what I have read, OAT (red) "does not protect copper and brass", but is that the same as not compatible ?
I have been using it in most of our stuff including tractors with copper radiators for several years, with no problems that I know of. Most copper rads fail due to impact damage, or the finning rotting away, which is not in contact with the coolant in any case.
I have used Prestone yellow stuff, which according to them is long life and universally compatible in our mini digger (Iron engine, copper rad). No problems with that either when I put it in a Freelander.
Does the Stag have ali heads ? All the things I have here that do, OAT is the recommended stuff but of course they all have ali rads. I have got a few Rover V8 engines here that have corroded waterways, they were all run on blue. The only one that hasn't got corrosion was run with OAT (red)
Also got a 1990 Lexus V8 engine All ali) that was run on oat, and the waterways look like brand new.
If it were mine, I would run it on OAT, or maybe find out a bit more about the Prestone yellow. Whichever you buy, get the ready mixed stuff, it is not much more expensive, and is NOT made with tap water.
Thats in effect distilled water rather than deionized.Yes. From me de-humififier
Minerals do not evaporate. At least not at the temperature required to evaporate water. Ergo, distilled water has no mineral content.Where they differ is that deionized water is water that has had all the dissolved mineral particles removed from it
Interesting.I've always worked on the theory that as soon as I shove de-ionised water into a car engine, it agressively gains ions and is no longer de-ionised - so my antifreeze simply gets mixed with tap water. Over three decades of doing so, nothing has corroded away yet - and I've own four of my vehicles for 20 yrs, all them older than that.
Same.I've always worked on the theory that as soon as I shove de-ionised water into a car engine, it agressively gains ions and is no longer de-ionised - so my antifreeze simply gets mixed with tap water. Over three decades of doing so, nothing has corroded away yet - and I've own four of my vehicles for 20 yrs, all them older than that.
Water is very hard here, and tap water ruins kettles and washing machines quite quickly through limescale, so surely this would form in the engine cooling system ? If I look in the bottom of the windscreen washer reservoir it is there too.Interesting.
I know ive used tap water in the past and not seen any issues.
The acidity in gas boiler condensate comes from dissolved CO2 (carbonic acid), on top of which the products of combusion include SO2, from the odorants, which are sulphur-containing molecules in most cases, giving sulphurous acid. There are also sulphur-based impurities in kerosene, so the same happens with oil burning boilers.Why is boiler condensate acidic ? Surely it should be pure, like dehumidifier condensate ?
During distillation, the boiling water throws up a fine mist of droplets, which still contain the dissolved minerals, and this mist drifts, carried along by the steam, and ends up in the condensate. The best quality distilled water comes from stills which have baffles before the condenser, to try and trap this mist, but even those don't achieve 100% efficiency in mist removal. Double distillation also reduces the impurity levels in the resulting water.Minerals do not evaporate. At least not at the temperature required to evaporate water. Ergo, distilled water has no mineral content.
So triple distilled Jameson Irish Whiskey is really pure? Not that I would top up batteries with it.During distillation, the boiling water throws up a fine mist of droplets, which still contain the dissolved minerals, and this mist drifts, carried along by the steam, and ends up in the condensate. The best quality distilled water comes from stills which have baffles before the condenser, to try and trap this mist, but even those don't achieve 100% efficiency in mist removal. Double distillation also reduces the impurity levels in the resulting water.
