My Old Landy
Engineering Mayhem
- North Lincs
Yeah, I am already £5k in with the stuff we have got. It's not really money making more fun!You’d have to flog a lot of trinkets to make that back![]()
What are you using for photo resist?
Clickspring on YT has some good videos for doing smaller stuff.
When you do your design, make it an outline, rather than a big solid block of colour.
Think of it like the grime under your finger nails - that stays there throughout the day, but, if it were the same grime on the palm of your hand, or the tip of your finger, it would be gone in no time.
The infill bond with the metal will be weak. Even if you etch it into the brass, brass is still a soft metal. The way you protect the design is the same as the way you "protect" the grime in your fingernails - put it down the bottom of an acute groove.
Something like print will just scrape off. Chemically colored brass may last, but not well. A single line engraved design will last the best. And, on a tool box, if the original infill does come out, it will just get replaced by grime anyway, and look very similar!
If you do a big block of colour youll loose it in a short time.
As a side note - you mention wax -
What they used to do would be apply the wax, clean off the excess, and then heat the part to melt the wax, to get that nice meniscus on the cut. But that would be unsuitable for your application as you would just loose the wax in no time.
@Dr.Al send Julian your design for critique, as I said he’s the expert here..
