- UK
That's the one
That's the one
Our mens shed was rewired last year by a 'professional' electrician employed by our landlords, the local council.correct the only time you need to earth the back box is if its a surface metal one or grid switches
Yes they do.Hey Brightspark, another question about things that go bang. Do smoke alarms need to be on their own breaker?
Yes they do.
Fire alarms.
From the breaker to the double pole isolated, in red, needs to be fed in fp200 cable.
The breaker has to be clearly marked, you can get red switch breakers.
240v with battery back up can be fed from a lighting circuit, but if they are interlinked or interconnected, it is advised that a separate breaker is used.
In a private house they tend to be of a domestic light breaker.For smoke alarms in a house?..
it is not advised at all it is optional and can be fed from a local circuit its not always convinient to wire back to a seperate mcb240v with battery back up can be fed from a lighting circuit, but if they are interlinked or interconnected, it is advised that a separate breaker is used.
https://www.google.co.uk/search?q=a...QVgQ9FVTQOQRpIHBDE1LjagB9SHAQ&sclient=gws-wizYou have no need to preach to the converted, I have seen it all.it is not advised at all it is optional and can be fed from a local circuit its not always convinient to wire back to a seperate mcbhttps://www.google.co.uk/search?q=a...QVgQ9FVTQOQRpIHBDE1LjagB9SHAQ&sclient=gws-wiz
no it isnt its a practical one and personal choiceYou have no need to preach to the converted, I have seen it all.
It is a difficult one.
When I say difficult, not as in hard work etc, but what is the best for the customer.no it isnt its a practical one and personal choice
yes a bit of a tight fit mind but doable. you can fit a flush backbox behind the detector to join them all if u wanted using wago blocks giving more room and short tails in to the alarmOne of the smoke alarms has two 3 core cables terminated. Can i add a third to this to 'spur' a new smoke alarm to it?
