It is not really anything to do with the strength of the joint it is how the applied heat effects the properties of the parent material now used for most car bodies
now that makes sense, thanks for that...
"Not acceptable for anything structural, or within a given distance of anything structural, I think."
Maybe I'm getting senile, but I seem to remember that most of the older cars (70s / 80s) the roof / pillar sections were brazed to the body by the factories???? that would be structural...
Certainly the trick frames for the motorbikes of that era and before were all gas brazed, so the stength is clearly acceptable, perhaps its the individual method that was in question.... gas versus mig... both being done properly, I don't see the difference, the end strength result should be the same? I would guess that mig being the modern preference as faster in terms of production, with less distortion, or am I talking bolloks....
10. Acceptable methods of repair
It is essential that repairs to corroded or damaged areas are properly
carried out. This requires that suitable materials of appropriate gauge or
thickness are used for repairs. Additionally:
• any plating or welding extends to a sound part of a load bearing
member
• the repair must appear to be virtually as strong as the original structure
with only continuous seam welding being acceptable for patch repairs
(even if the patch extends beyond the prescribed area).
• spot welded joints are acceptable where the original panel has been
replaced to an existing spot welded flange (provided the original
defective panel flange has been removed). Stitch or plug welding is
acceptable as an alternative to spot welding in these cases.
• MIG brazing, a combination of adhesive bonding and riveting, or
amalgamations of these with other joining methods may be the vehicle
manufacturers recommended method of repair. Such repairs must
therefore be accepted unless they are clearly inadequate.
11. Unacceptable methods of repair
Gas brazing, soldering, adhesive bonding, fibre reinforcement and body
filler are bonding processes and are not regarded as strong enough for
repairs to load bearing members although they are normally adequate for
other repair work.
In years to come when these boron steels need repairing due to corrosion its all going to be pretty academic how they're joined in. Anything will be an improvement on rust.
I very much doubt people will be making patches from Boron steels either.
I realise that presently we are talking about crash damage repair not corrosion repair.
