Sparks
Start em young. ;-)
Sparksy, I think I know where you are coming from with the not seeing bit. When I first started migging (is there such a word ?)
If it isn't I think there should be. ;-)
I found it a bit hard too , but the more I do I better I see what I am doing. I find I really have to concentrate to see the puddle though. I now have twin 40 watt fluorescent tubes about 3 feet above my bench which I found helpful.
OK, so I'll try putting some extra light over where I'm welding and see what happens (I was going to do that in any case for general use).
If you were doing a fillet weld, could you typically see the whole area you were welding into, clearly see the sides of the fillet etc? I'm sure I used to be able to see such things but I can't now, not even a blurred / out_of_focus version.
I'm hoping it is just something silly ... like some film left on the mask glass ... or the mask gone wrong or not set correctly (although I think it's only got sensitivity ajustment, not dark / light etc) or just not enough light on the job.
I used to be reasonably good at welding, I think I had 'the feel' etc (even when learning welding at college) and am frustrated that I can't be as good as I know I can or have been. (I'm not saying I was ever brilliant or up to professional / coded work, just that none of my diy stuff has ever fallen apart). ;-)
Cheers, T i m
