the snooper
getting older by the day
- Hull UK
did you refit the original exactly as it was with the brass part of it firmly connected to the wire feed mounting plate ?ok I will need to get a longer lead still cant work out why the old torch has stopped working just tried again should work as the cables aways been on the back of the wire feed
if the brass part bolts up to wire feed plate that should do it, if it still doesnt work when you have done it , take pictures and post on here
