you seem to have yr head locked in the mode of if it is not 100% right it is no good.
as tig welders, most do strive to master the art, every thing needs to be spot on the produce that perfect weld,
yes we all know this, you are not teaching nothing new
but surly you have heard the term, "fit for purpose" ????
I am not even going to argue if a weld, done on clean carbon steel will or will not produce porosity.
so we have this autogenous weld, done on carbon steel, even with some porosity.
are you trying to say it is NOT fit for ANY purpose?????????????.
as I said, there is a disscusion going on on an other welding forum, regarding this very topic,
one guy is saying, he works in a factory that builds cookers, he is claiming that on some parts NO FILLER wire is used, (brackets etc)
Are all these cookers no good then, should they be sent back????
I think the answer is NO.... BUT if it does not have to be strong then maybe! lolWhenever i bring 2 pieces of steel together (thin) by just melting the two ime a little concerned the metal goes brittle with the process....Do i always need to use filler or is the "fusion" method consided a decent joining process in terms of strength??
