rallyreturn
Is It Finished Yet ??
- Pontypridd Wales
Just standard Tarmac rear arches from Rally WeldThat's looking great, makes me want to pull my finger out and finish mine.Are those rear arches monty's?
No they are rallyreturn's -------nowThat's looking great, makes me want to pull my finger out and finish mine.Are those rear arches monty's?
It'll be a one piece prop, be a long time before it gets fitted and I'll be dry fitting everything before painting, so if it does foul then I'll cut it out.what prop are you using? if large dia group 4 one piece, you might need to remove the old seat belt mounts in the tunnel for clearance on full bump-----![]()
wow fella good patience great work I have just put a lotus mk2 back on the road it was a real basket case but fortunately never welded prior to me owning it... well when I say never welded it only had a minimal amount of brazing but loved every minute of it knowing that I will finally get to drive an icon of the 60s and now loving the looks and the waves the sound of those twin forties nothing quite like it.........the car will be at a garage quite close to you soon in llantrisant if you want a trip round the block give me a shout
Problem is the muck gets blasted into the join and then shows on the body through the joint also if the arch takes a knock it tends to pull out where there arnt any rivets the tiger bond tends to support it allway round and can stop the electro action with the ally rivets. IMODidn't use any sealer, just made sure there was plenty of zinc primer on both the panels and arches.
Sorry did not read fully.....my concern with Tiger seal is later removal is needed. How easy is is to part panels once sealed with Tiger seal?Problem is the muck gets blasted into the join and then shows on the body through the joint also if the arch takes a knock it tends to pull out where there arnt any rivets the tiger bond tends to support it allway round and can stop the electro action with the ally rivets. IMO
if the old arch is totally flattened, cut off where it bends up to the vertical, the end of the is pulled away you just roll the strip up cutting the sealer with a blade.Sorry did not read fully.....my concern with Tiger seal is later removal is needed. How easy is is to part panels once sealed with Tiger seal?
I agree but the arches are hard to repair when pulled away and stretched you end up with a wavey joint with the rivets partially pulled out that is very hard to sort whereas if bonded the whole lip seems to stay straighter.looks just as good with the rivet heads showing.
