You could do a Dinse plug conversion like the new oxford i bought where you can spec the pos or neg torch.you could then run gasless wire too.Maybe it could be time to fit a new rectifier. it did weld well when my bro had it, quite why the recitfier is wired in reverse?, heaven knows.I think id source it from technical arc rather than the bay.See the oxford section for my review.
Also i take it youre using a multimeter to ensure correct polarity?
OXFORD review
Matt, to change the polarity of the rectifier: mount it upside down ( the whole thing ). Then the pair of plates that are stamped "-" will be at the bottom, and connect to the red wire ( = ground clamp ), and the pair of plates that are stamped "+" will be at the top, and connect to the black cable that goes to the torch ( positive ). The wires will be in the same places, and so length will be OK.
With the rectifier upside down, the AC input connections ( the U-shaped metal bridges that join the pairs of thin flat plates with rounded ends ) may be swapped left-for-right, but that doesn't matter - since AC swaps backwards and forwards 50 times per second anyway!
You may have to shuffle the central stud downwards in the stack of plates, so that there is enough free stud to bolt to the mounting bracket at the bottom.
