Ah yes, there are a few hits which suggest MJ15015 as an alternative for a BDX18. RS do stock those, although typically they're not in their core range.
The datasheet for the GO Semiconductor MJ15015 that RS supply does show that the collector and the emitter connections are reversed on this compared to the datasheet for the (I assume) Comset Semiconductors BDX18 I have here.
It would make it run at full speed, with no control.
One of the RS transistors should work, It's just, a big low gain transistor.
An NTE219, or an ECG219 should work.
Even an MJ2955 would probably work,and it seems RS carries them.
Robert
