Still on about the Lathe,does anyone have these fitted to their mini-lathe and are they worth the effort of buying?
http://www.mini-lathe.com/Mini_lathe/Reviews/Sieg_DRO/dro2.htm
Arc Euro trade knock em out for £84.
Cheers.
How do you fit the DRO readers so that it "understands" the compound slide?
I was thinking of sticking a DRO on my little myford too, but I'm confused how it measures the tool position.
What I mean is that the saddle obviously moves sideways, and then you have the cross slide that goes in and out, but the compound thing that sits on top of the cross slide can move "angled".
The original primary purpose of a Lathe was for turning shafts & facing disc's (every thing else was achieved with attachments) & the tool-post was fitted directly to the cross-slide.
For screw-cutting you had to have a different lead-screw for each thread you wanted to cut.
To cut tapers you fitted a taper turning attachment (also called a compound slide) with its own smaller tool-post, cut the taper & removed the attachment.
Somewhere in the mist of time, some lazy bas$$d couldn't be as'd to shift it & by 1900 most lathe makers were supplying "with taper attachment fitted" I have some old machine catalogs pre 1880 & all show the compound as an extra.
