Used it just before that and now that I’m used to it, it’s so easy to use. In answer to your question, yep extremely pleased I’ve been in contact with a Tom from WeldingSD so I suppose it’s one and the same.
I wouldn't base my decision on whether the welder has or hasn't got synergc features.
They are a good starting point for beginners, or in the expensive welders for aluminium.
I've seen miller migs welding aluminium on a pre programmed setting, and I was very impressed.
I personally wouldn't require synergic settings for a mig, I learn the settings as the jobs come in,
I change the settings to suit, and tend to remember them for the future, or write them down if need be.
Have you looked into portamig, or technical arcs own migs, to me the portamig internals look neat.
Here is a nice one from technical arc,
https://www.tbws.co.uk/shop/tecarc-t-mig-321hd-industrial-mig-welder/
I like the two fans on the side approach, they pull heat off the transformer and the diodes
in what seems to be a more practical and efficient way.
No, I lsold it.
It had lots of power and was smooth at high settings, but a lot of the work I do requires using lower settings too,
an I always had a cold start to the runs.
The oxford did not have a separate transformer for the feed motor, this causes issues, the main transformer
has a tap for the feed motor which means it effects the feed motor when engaged in welding.
That's why I went for a different mig this time around. I think they use capacitors in the tech arcs too,
email them and ask.
[QUOTE="johnyev, post: 1736763, member: 21465"
What is this welder which is not Oxford, Oriya or Tec arc ? ( abra weld)Which is spoke of?
Can’t answer your question re the differences, but from my experience, don’t think you can go far wrong with the Oxford.Instigated by this thread - I'm going to order an Oxford MIG soon - question is, should I go for the Migmaker as Nick did ........
Nick DV should be on commission
I recommend @Tom Orrow L as I knew he supplied Oxford migs and when I spoke to him he couldn’t have been more helpful with his advice and supplying the mig. Good customer service and equipment means more than ‘discounts’ It would be useful to know what issues you had with the feed motorNo, I lsold it.
email them and ask.
I'm surprised that TecArc would take that cheap route and power the wirefeed motor from the main welding circuit. As a111r said, this is done on cheap machines, but the initial voltage drop when striking the arc and the voltage varying with the arc length causes stuttering variations in wire speed. Perhaps TecArc rely on the capacitors to stabilise the voltage?The Oxford did not have a separate transformer for the feed motor, this causes issues, the main transformer has a tap for the feed motor which means it effects the feed motor when engaged in welding.
Yep. Tec-Arc is the UK Company that makes:
Oxfords, (Non) Portamigs, Their own brand (Tec-Arc), plus Abra branded machines.
There may be more?
I looked into the ins and outs when i bought my 270-1
Apart from the colour, Portamig and Tecarc (also Britarc) are side loading machines, Oxford is a top loader - depends on which is more accessible and easier for your situation.
Oxfords include smoothing capacitors, Portamigs now have them fitted as standard, I think it is optional extra on the TecArc.
You can specify either 4 or 2 roll drives on the portamigs and tecarc machines but they are plastic ones until you get to the 285HD then you can get a metal 4 roll on the portamig and metal 2 or 4 roll on the tecarc.
On the oxford you can only have 2 roll unless you go to the I-MIG (330) range as the layout is too small to accommodate the 4 roll drive - however I believe the oxfords come with a better quality metal 2 roll drive than the portamig or tecarcs.
Any of the machines from the 270 and up have 16 voltage steps.
Duty cycles at 35% for the Portamig are better than the Tecarc, the Oxfords are lower until you get to the IMIG range. I think you can request special factory options for all of them to increase the duty cycle, but I can't remember the details.
Oxfords go down to a minimum of 20 Amps.
The new version of the portamig goes down to 15A on the smaller units and the 285HD and up are 25A.
The Tecarcs are 20A until you get up to the 285 and it jumps up to 35A
Tecarc and Portamig are the same size chassis, Oxford are slightly more compact (shorter).
I think that's right.
