Hi...
I have an 85 amp Dayton 6Z935C MIG welder that I'm happy with for now. The only problem is that it has a wire feed roller with .030" (0.8 mm) and .035" (0.9 mm) grooves. (This is because the basic welder is set up for gasless welding; mine has the gas kit installed and I use it with 75/25% Argon/CO2.) I'd like to find a roller for this machine with a .024" (0.6 mm) groove, so I can try thinner wire, and was hoping that by posting some photos here the many experts on this site might be able to identify the actual manufacturer and point me to a supplier. The welder uses a Tweco gun; I don't know if the feed mechanism is generally matched to the gun or not.
To help with identifying the welder, it has four heat settings plus a fan setting; the highest heat setting is blocked by the selection knob in the photo.
Any help is greatly appreciated!
