have you made the cutomary gas bottle wood burner ready for winter
My van has no signwriting either.........
looking good but what are u doing with the blocks rendering them painting them or just leaving??again another small update
this weekend i tried to smash the remaining exterior cladding that still needed to be done and i reckon i got a good 90% of it done, just a few more planks to go and it'll be done! thank god!!
I fitted the fascia boards to the front and trimmed the roof shingles to match. I also need to make a couple of boards to cover the inside edge of the garage door opening.
the lion share of teh work was spent cladding the end wall and fighting the tree/bushes in the corner which made teh job 10 times harder! just nned to make a couple of fascia boards for the end and cut the shingles to match as well
so things still to do are
1) make end fascia boards
2) cut shingle to match
3) seal shingle edges down
4) make door batens
5) make window frames
6) get windoow glass
7) refit side fascias
8) fit guttering
9) finish lining inside
10) finish cutting roof insulation baords
11) finish lining roof
12) install plug sockets
13) install lights
14) fit wiring
so not much then!!!
Snooper if you look closely you might be able to make out the DPM between the top of the breeze blocks and concrete base so no moisture should travel up.
