DAPPH
as dyslexik as I'm daft
Having recently spent £3125 on having a full three wall internal of thermal concrete blocks built inside my garage & a full self supporting 150 mm thermal insulated roof plus a new up & over door frame of treated wood as the rain poured in through the single skin walls & via a bad roof fit on the next door neighbours half of the semi detached garage.
I had to decide what sort of lighting I would put back when it was rewired .
Initially I chose to use the two original 1.5 m T8 fluorescent strip light tubes and as they were not quite bright enough added a 10 & a 30 watt LED flood light to give me a white light over the lathe and drill press areas.
That cost me about £50 in total for it included extra cable and two inline waterproof cable connectors as well as the two three pin plugs . I chose to have them mobile rather than fixed so they can be moved around to give light as & when. it might be needed ( they are good inspection lamps as well ).
Much impressed with these new solid state big yellow blob LED flood lights I convinced my lass that we should replace the T8 tubes with the latest 20 watt T8 LED replacement tubes . Two days later Alison calls me to the garage saying, " This strip light has just died on me, perhaps it's time to buy a pair of replacement lights ".
I then spent a few hours on the internet looking for the cheapest price with a reasonable delivery time .
I bid for a pair at £ 9.45 and yes actually won them including FOC delivery & packing . ( My local wholesaler wanted £ 23 per tube plus VAT ".
The tubes arrived this morning well protected and packed but would not fit into the end / cap sockets on the light fittings.
It was because these new tubes have a slightly oval end cap instead of the normal round end cap that you find on the old fluorescent tubes . There was a slight shielding lip on the sockets would not allow the tube to locate . A few seconds with a sharp pair of side cutting snips & a pair of end cutters saw me snip off these lips ,then file the remaining rough bits till everything was nice level & smooth .
The seller informed me that you have to take out the starter units ..which I did .
Once the tubes were put in place I switched them on .. WOW ! amazing instant light , no warm up , almost as good as bright day light without any flicker whatsoever.
To check things out I set the lathe to run at 300 rpm , to make sure that there would not be any of the , " Being on the same cycle synchronization problems " . The chuck was easily seen to be rotating around 300 rpm & not almost marking time like it did on the fluro tubes .
I don't yet have any pictures of the lighting quality but hope to take some tomorrow and post them up .
