DAPPH
as dyslexik as I'm daft
You may find it's a better light without diffusing it , perhaps a clear acrylic panel or even nothing would work better so long as you get the reflector set up right ..
The wattage :-
that will be a 5 mtr roll of LED at 60 watt with respect to the voltage applied.
That's why I asked about you using a transformer /driver or battery etc for them as 6 to 30 volts DC at 20 watts rating is a lot less energy in coloumbs ( electrons on the move per second ) used than 20 watts at 240 volts rating .
I'm not sure what these new super bright high energy ones draw but it is not much & obviously it alters with the adding of surface areas being used in each LED .
With the old ( Last century ) encapsulated LED's , if my memory serves me correct there was a 0.6 volt drop across each led in the circuit , though you could have them wired in series ,paralleled or a combination and have three or four circuits per length running from common buss-bar /rails .
The wattage :-
