could you explain why and when you use etch primer.Cool, sounds like you're on the case, the etch primer was a good clue you knew what you're up to!
Nothing to forgive at all mate, beauty is in the eye of the beholder and you're never gonna like all "art"could you explain why and when you use etch primer.
Please forgive me if I say now its painted I can see its artistic value as a cut piece of steel I was not so sure....but then again I dont like Van goghs or stuff like that.
Thank you for the good explanation johnser. To be perfectly honest I'm not sure if what I've used is plain high build or etch primer. I'll have to check when I get home tonight.Etch primer does just that; etches the metal it sits on to provide a good key. This is particularly important for "reactive" metals like zinc, aluminium and magnesium which generally like to peel and flake their coatings off. Add in that most etch primers are zinc rich too and you get a bit of electrolytic protection, plus, as mentioned, they are usually pretty high build so good for covering blemishes. A decent high build primer will be cheaper though if this is all you want to achieve.
I use it on any metal that is clean but not well keyed. Don't know how it behaves with stainless... But when do you paint that?
