phill d
- slough, berks , England
For anyone on here with outboard engines, here is a nice project i made for myself and something
that I needed but would of cost me a fortune to buy ready made from a marine outlet.
I have seen and used all the wooden types and find them not realy good enough for my use.
Plus you still have to get the engine from the boat to stand or stand to boat etc.
I looked around at outboard engine stands and noticed just how expensive they are.
Not the silly barrow types for max of 40hp to be safely pushed about, i needed one to hold a
much bigger outboard.
So in my wisdom I decided to make one that will cater for whatever outboard I might come across.
With me allways making stuff that's far to strong, I decided this must be capable of holding
a 300hp v8 outboard to work on.
First thing was obviously to get some wheels, Thanks Tesco for leaving out a few scrap trolley's.
( well I think they were scrap ).
Then I needed to clean up a load of 2x2 strong walled box section to make my base and uprights etc.
I used a grandson for the cleaning up with a flap wheel on a grinder, I found this to be very easy
for me and only cost a few bags of sweets and a flap wheel for the grinder.
The result was perfect in that I can simply unbolt the main uprights that hold the main plate
the outboard bolts to put it in garage as flat pack standing up etc.
also I made the main uprights so they can be raised of lowered so can take from shortshaft to
extra long shaft engines, this can be a difference of 10 inches.
with the large swivelling wheels it can be simply manoeuvred around and very safe to work on
a outboard engine even with engine in full tilt position.
this had to be made so the engine could be lifted from a boat to the stand, so I made a couple
of 6ft uprights to bolt on the side and the back with a hand winch to raise and lower the engine.
Once the weight it taken the normal uprights are removed leaving the engine hanging and can
be simply pushed to the rear of the boat with trolley going under a trailer letting the outboard
be fitted to the transom of the boat.. by using a geared winch this can be done nice and easy
and safely.
the engine in the pics is only 130 kilo's, but ive got a 600 kilo winch to make sure its safe.
and simply do the same in revers to get engine from boat to stand etc.
Also I made it so a couple of simple bearers can be placed across the chassis to take a 100 gallon
water butt for engine running and testing, this is a very stable outboard testing set -up especially
when the water but is full. The front step looking platform hold battery and fuel tank.
we have used this a few times and it makes life so easy, yes the engine can be lifted by 2 people to
fit it to a boat, but not in safety.
The engines are top heavy and if they fall can do damage that cost a fortune.
I have seen similar to my available in the states and they cost around £1,000.
Mine cost me a bit of mig wire, 3 bags of sweets for grandson, 3 flap wheels and a tin of
silver hammerite, so not much at all.
anyone can build this very simply and have a nice safe platform to work on the engines.
it can hold upto 3 seagull outboards or 2 x 30hp side by side or 1 x single upto a max of 300hp
here is a few pics of said outboard stand with and without a 60hp on it.
phill
and safely.
phill
