..... So the answer is if you're going to use a single insert, use a finer pitch one with a narrow flat then you can over-cut the depth a little for coarser pitches but you'll have to keep test-fitting the nut if you want a close fit.....
I religiously thread with hss tools. I made a set of 55° and 60° when I first bought the lathe and I’ve never had to touch them since. I cut with carbide as I prefer the finish but thread with hss. I just take it easy with threads, slow speed and a small progression on the top slide every cut.
Ha I wouldn’t even attempt that on mine. I pluck away at the slowest speed of 48 rpm when cutting a thread. Nice and easy. No rush.but trying to cut coarse threads at 600+ rpm
I don't attempt it - but it's the sort of speed that carbide wants! I thread as fast as I can cope with, as even HSS likes about 40 fpm and that works out at 640 rpm or so on a 1/4" thread... Which I would probably thread at 200 or so, then thwack the clutch lever as I got near the end, dropping it to about 40!
I've used a Hardinge a few times, they happily thread at 600 RPM and have a very handy single-tooth clutch in the leadscrew drive that disengages at an adjustable stop, like some of the other Holbrook and other toolroom lathes, makes threading a relaxed and pleasant experience
I must make something similar for mine, given the Tuits, I've got the CAD models for various parts done...
In the meantime, I've a Coventry die head, another easy-threading option (but the dies are a fortune).
Dave H. (the other one)
I'll do you a demo of threading at 1000rpm when I get my Hardinge rebuilt. Been looking forward to it![]()
Threading inserts question
I've done a little external threading using a carbide threading insert and the results have been acceptable, although I discovered that it is very easy to break the tips off.
The tips I bought, you simple choose internal/external and the angle, 60° in my case.
I see now that there are tips available for pretty much every thread pitch too; you can get a 16 tpi insert and a 12 tpi insert and so on. Is there any great advantage in using these rather than the the 'general' 60° ones I have?
