Hi All,
A friend recently gave me a collections of bits which I've put back together into something resembling a compressor.
I'd estimate it's from the 80's/90's, Receiver is branded Draper, motor Red Devil, and the pump I can't ID, but the filter box has a logo on which I think may be Airblok. Looks like this:
From what I can see, seems worth saving.
Anyway, rebuilt the pump and it's moving decent air, but haven't yet connected the tank. I'm a little concerned about whether or not it'll be safe to use.
I've shone a torch in the blow off port and taken a photo at the outlet, and there's clearly some corrosion in there. Photo below shows the drain valve end (I'm going to try and get a scope in the tomorrow to take better photos all over)
Does that look bad? It's been moved around a lot in a car hence the flakes all being at one end.
Tank plate here:
Spoken to a few dive vessel places who will test it for £50-£60, and it seems that basically what they'd do would be fill it with water, pressurise to 1.5x working pressure, and hold it there for a few hours and check for leaks (something I can do at home)
If it passed that test, would you consider it safe to use?
Thanks in advance
Tank plate here:
Thanks in advance
