Unfortunately it’s not that simple, you need active components like CO2 and O2 in the shielding gas when welding steel to help focus the arc and give you fusion otherwise the weld will just sit on the top of the parent material, there is a mountain of literature which makes it clear which gases to use for which materials, no need to go re inventing the wheelok so pure Ar is the way to go for spray tranfer, i always learn something on here
It a bit of a guesstimate but 5% CO2 for sheetmetal, 12% up to around 6-8mm and 20% for heavy stuffAahhhh not trying to, only getting the correct info and you seem to have it.
I know CO2 is needed for penetration thus the mix Ar / CO2.
Seems logical to have a minimum CO2 in the mix.
