MichaelV
- Co. Antrim
Richard, you know I like to have the theory behind it and not take things in just because I am told it is so! I would also say that the rod is not in contact in either DCEP or DCEN with the work piece and that you have an arc in either case, this section in the book is taking about arc welding saying you get a deeper crater with DCEN, to me a deeper crater means more pen.
The analogy to TIG was my own in that, and to my mind, consumable electrode or not, if I had a setting on say 2.5mm steel of 100 amps and was running DCEN the heat is in the metal not the tip as the tip can withstand its own heat build-up with the gas cooling, but if I went DCEP the tip would ball up as now most of the heat is happening at the tungsten.
So I associate the most heat with the most belting, bigger crater and more penetration.
Looking for my Lincoln Tome now to see if it says any different.
Adrian
Also of note when I was having issues with trapped slag in some of my welding a dealer suggested I use DCEN as it gave more pen.
Hi Adrian - a useful, albeit summary explanation here: http://www.twi-global.com/technical...elding-which-electrode-polarity-should-i-use/
Michael
