Bill Edwards
- Scarborough, North Yorkshire
Thanks.
My thinking is that if I get the top support halfway (ish) then it can take at least half of the weight, effectively turning the gate into two sections - one gate hung by hinges, the other half held by the brace. Two smaller sized gates, either of which will be fine to take their own weight - I'm just splitting the big one into two really, from a weight/force point of view. But knowing exactly where to put the top support was something I wasn't certain about.
Fitting the hinges right at the top or bottom is a good idea but less than practical as it needs to be easy to give them a tweak from time to time as things drop - hopefully not the gate, but the hinges will certainly wear after a while. Anything other than easily purchased, standard gate hinges are best avoided for this because if they seize, break etc it needs to be easy to cut them off and replace them without any fabrication.
The whole thing is a little wobbly with 40mm box, but that isn't such an issue, it's the thing bending anywhere that causes concern.
