richie00boy
I've never welded before but seen my dad do loads of gas and arc. Would this inverter welder be any good for underside patches on cars? And making things from 1 inch square tubing?
Just bought one today. Will give it a whirl and let you know. Looks cute and seems of reasonable quality. The accessories mask etc are tosh. But for £80. Worth a whirl.[/QUOTE
I have been playing with said machine today. Sorry the machine was £69.99. But I bought a pack of rods and a mole grip set.Just bought one today. Will give it a whirl and let you know. Looks cute and seems of reasonable quality. The accessories mask etc are tosh. But for £80. Worth a whirl.
It performed amazingly. Especially with the 2.5mm rods at just under 80A. Very stable arc and easy to strike. Good penetration, nice clean welds. Overall I am very happy. I burnt one 2.5mm rod off in one run with no thermal cut out and the machine did not feel hot at all.With the 2mm rods on thin 14 gauge plate it was tending to blow through at 50A. But I recon with 1.6mm rods and 40ish amps it will be okay on thinner material with caution. Well worth the money for the diy'er and small jobs it is a tiny machine and very portable. Uses standard 13A plug. Absolutely ideal.
That bloke is amazing. Do you think he is doing double denim? It looks like he is using a 4mm rodIf it makes you want to try to weld an aluminium stem with upsidedown handlebars onto an old style steel seat clamp that's sat on a slip plate, then yes - there are cheaper ways to go mad, like absinthe...
That bloke is amazing. Do you think he is doing double denim? It looks like he is using a 4mm rod and striking an arc from 2" away onto aluminium tubing. Obviously making a lazy susan with handlebars and brakes. Ideal for slowing down your chow mein if it is spinning to fast.If it makes you want to try to weld an aluminium stem with upsidedown handlebars onto an old style steel seat clamp that's sat on a slip plate, then yes - there are cheaper ways to go mad, like absinthe...
That would good, thanks
Errr, I'm after the tray as per my pic.![]()
Out of interest having never owned a stick welder, aside from not having to use gas, portability and no need for a 32amp supply do these small inverters have any advantage over a 215 amp mig? I.E in what they're capable of / more suited to?
For the weight of the steel you describe, 2mm to 5mm for example, it would manage that easily.Found this site whilst I was looking up about welding.
Never welded before but would like to learn to make simple shelving, table bases etc out of box section. Nothing fancy so this seems like value for money but is it up to the job?
is scratch tig the same as lift tig?
They are both contact ignition processes but quite different in how you make that contact.is scratch tig the same as lift tig?
Only 80 amp, Aldi 140 amp
