.  That, and maybe 3mm was a bit ambitious for a reduced air supply. I'll try something thinner next time. Luckily I've ordered more spare consumables........
   But at least I've proved she wasn't DOA
 Look forward to hearing how you get on once you've replenished - I can send you up a handful if you like
Mine doesn't have pilot arc but it could do 3mm all day, on the sheet or a few mm above it. Your PSI could maybe go up a bit but it should cut
That said, if you don't have the correct consumables then I suspect all bets are offLook forward to hearing how you get on once you've replenished - I can send you up a handful if you like
.  Not that it's a deal breaker, I dare say I'll manage as is.Has anyone changed from basic PT31 torch to AG-60 style torch? Some have said it would give more cutting power and longer consumable life? AG60 torches can be had for a tenner from China with better looking trigger as well, but will the fittings fit? I don't have a plasma but was wondering how it would go.
] pipe which goes to the gauge and fitted in a length of clear, bendy plastic stuff I had lying around and which is a tight fit over the existing one.  Fine until I connected the compressor...blew one joint off
. Now Araldited, leaving overnight and will test tomorrow.  If it holds, I'll separate the other joint and give it the same treatment.
Have you managed any more play time with it?
Adrian
, so I've wrapped all round it with self-amalgamating tape for the moment [Heath Robinson is alive and well and living in the frozen North
  Burned out a number of tips, but luckily the extended consumables I ordered from bang_good arrived very quickly [DON'T make the mistake I did and Google 'goodbang'.........
]  https://www.banggood.com/60Pcs-Air-...-p-1028100.html?rmmds=search&cur_warehouse=CN
