Exactly, just switch it off, back on when you want it.It’s 20 years old, I can’t believe there’s any sort of shut down sequence as it already has an on/off switch which cuts the power straight away.
Hmm, 2000l for a well insulated house not doing hot water either is a LOT! For comparison, our oil runs an old inefficient wick Rayburn over winter and does a bit of heating and a bit of hot water. Also have thick walls but barely any insulation on them. Uses just less than 1000l.
I would keep an eye out for a second hand condensing boiler (Grant?) there are plenty around on marketplace generally for £50-£250. Then set the thing up so the return temperature is optimum under normal use.
You don't want that boiler cutting in/out on its internal thermostat. There's a huge chunk of steel and water in there that takes a significant amount of energy to warm up. Using it to warm just a couple towel rails is horribly inefficient. (Go electric on the towel rails?) It also looks like the boiler is in an unheated bit of the house so, potentially, all the heat that leaks from the boiler is wasted.
Compensate for this by running in batches, hot and hard for as short a time as is practical. Any time the boiler is up to temperature, (if it is in an unheated space) it's wasting energy. Would be a frugal option to run a pump overrun timer too, so your pumped radiator circuit keeps circulating for some time after the boiler has timed out to drag a bit more heat from the boiler back into the house.
Don't be scared by a heating controller but if you prefer a timer, as you're only running one channel anyway, a controller will only offer you the option to do day by day programming rather than the same setting every day.
What puts you off lpg is it the price
Solar is popular here - a friend has his barn covered plus an array in his garden that tracks the sun.Even bulk tank supply, your prob best with heat pump and solar in the long run
I’d say go for it, nothing to lose - the timer will only be doing exactly what’s you are doing now. But there are also other, possibly better, options to consider and look into afterwards if you wanted to.I’m not minded to change the whole system at the moment - don’t have the funds to do it! What I do want to do is not heat the place unnecessarily hence wanting a simple timer to give us a bit more control rather than me going outside to flick a switch twice a day.
It won't need it, no. Evidently it works now without. But an overrun timer will help draw down residual heat from the boiler, into the house, that would otherwise be lost to the outhouse. A cheap but marginal improvement.it wont need overun the boiler is basic on and off and if it did have the internal clock fitted it would only be a single channel timer
