MetalMonkey
- UK
Not possible. The air is already plumbed in and claw connector and air lines won't be flexible enough for the situation. ⅜" bore is what is recommended by trelawny.
You could just try swapping the end of the hose and the fitting on the scaler to PCL XF - don't need to change anything else, they are cheap and should give you an easy boost in flow rate on your existing 3/8 line.
