).Is a high gloss finish (or should be I hope).
Cheers
Max
If you want a high gloss finish you need some good quality high flash thinners for the top coat. Don't go for the fastest, medium is good so it doesn't dry out as you put it on. I use some Palinal make which works well, our local paint supplier carries it but it is dearer than your gunwash/primer thinners.
Was it me to heavy handed with spray gun?
hate to ask,but where is the gloss????
is that a metalic paint? if so you will not be able to plolish it too much.
without cutting thru to the paint.
